Hello fellow mariners,
I was trying to find a thread about no oil transferring from remote tank to engine tank but it seems the replies are deleted for some reason. So I know this will ruffle a few but my Yamaha 225 will not transfer except by toggle switch. The digital tach has three symbols. With key on symbol on left will blink for about 30 seconds then goes solid then center symbol blinks and nothing out of third. Tried pulling sensor from engine tank and manually moving the floats. Bottom float sounds alarm and makes symbol on left flash but top float doesn't have any effect(used dvom and didn't get any resistance change in harness while moving top float like I did with bottom). So do I have a remote tank float problem(thinks tank is low) or a float issue in engine tank. Already replaced rusted out oil transfer pump(old one didn't work anymore) and don't want to throw parts trying to fix this. Any help would be appreciated.
Thanks!
Thanks!
