Hi, Im new to this forum and not used forums before but hoping to be able to find some advice ![Smile](https://www.yamahaoutboardparts.com/core/images/smilies/smile.png)
I recently purchased and installed a 95-96 60hp precision blend on my runabout.
Before taking the kids out or for a major fish I decided to take it for a run down a local river and out in to the estuary to make sure it was working ok.
First thing I noticed was that the rev gauge wasn't reading but thought that its likely been wired incorrectly.
The motor ran fine until I reached the estuary where I cruised at about 30kph (I can only provide speed not revs) for a few minutes and it was running fine so I opened up to full throttle and it peaked at about 54kph for approximately 20-30 seconds before a sudden RPM reduction and it dropped down to a steady 20kph.
If I turned the motor off for a minute or two and ran it again the same thing would happen, It would happily climb to 54kph for aprox 30 seconds before reducing RPH and speed to 20kph and no more. It wasn't spluttering or erratic it just maintained revs and speed as if it had reduced itself to a safe/overheat mode.
I took it back to the mechanic that installed the motor and I was told that id likely picked something up (weed) around the prop causing it to overheat. They said that they had taken it to the estuary and tested it whilst on the trailer and was working fine. but unable to determine why the RPM guage wasn't working.
I took it out the next morning in the ocean and after a minute opened up to full throttle and it did the exact same thing again. If I let it idle for a few minutes it would allow me to do the same thing but every time the RMP (even though my gauge isn't working im going of sound) would reduce to the same RPM and idle there.
The mechanic is unsure as to why it is overheating or going in to safe mode but I wondered if it could be related to the RPM gauge incorrectly wired or whether its likely a genuine overheating issue.
Other things ive checked is that the oil is full, battery and terminals are near new and its meant to have had a service before installation so im assuming the carby etc is clean.
Any advice would be appreciated.
