New to forum. Hello.
I have a (low useage) 1985 Yamaha 2 stoke, recoil starter OB. Previous owner installed new lower unit 5 years ago, so 'it' is (was?) in good shape. Motor was running well until I replaced the impeller, this season. Now locked in 'F.' Problem is NOT in the powerhead. With LU removed shift linkage works fine. With LU on work bench there is no movement in the shift linkage rod. Gear box is engaged, and turning drive shaft causes propeller to rotate in a 'forward motion." Any suggestions on DIY resolution for this? Not likely to take a 30 year old motor to a service center but if anyone has an idea what professional repair would cost on this that, too, would be helpful. Thank You.
