Does anyone know what part numbers needed to fit a 2015 VF225LA SHO four stroke on TR20 That has analogue gauge now, repowered from mercury to Yamaha.
1. Get a compatible DIGITAL TACH - which tach can be used (command link or ?)
2. TACH HARNESS. Need tach harness to gear control, maybe two feet distance, thanks.
2a. Is this the correct harness number to connect the gauge to a four stroke: 6Y5-83553-NO-00
These are listed all over which fits this motor and which harness to get:
Added for clarification, engine tach’s - are they all compatible with VF225LA four stroke?
6Y5-8350T-80-00,
6Y5-8350T-83-00,
YAMAHA 6Y8-8350T-11-BK,
YAMAHA 6Y8T-11,
Part No.: 6Y8-8350T-1
6Y5-8350T-84-00
Come to find out that you can not use the harness off of the 6X3 THROTTLE/GEAR LEVER to hook up a 6Y8 command link - Hub or a 6Y8- 8350T-20 tachometer. Back to the drawing board. They said only the 6Y5 versions would work.
6Y5-8350T-80-00,
6Y5-8350T-83-00,
YAMAHA 6Y8T-11,
6Y5-8350T-84-00
