I had an issue about 100hrs ago with my throttle adjustment. This has been fixed and the issue never came back as per my previous post. This problem happens very intermittently (happened 5 times maybe in many hours of driving) and is triggered by my con*****er I believe. When taking out of gear my con*****er all of a sudden gets very stiff right as it clicks into neutral position to idle, and my idle jumps to about 1200. It will stay there and it is very stiff to shift into gear and of course shifts hard at that high rpm. I usually then shut off the motor and work the con*****er a couple times and it goes away and runs perfect. I will be taking apart my con*****er when I unwrap the boat in spring but getting a head start on research first. Any thoughts?
2004 F115 con*****er sticks
check your cables for cracks /splits in outer casing, and rusty looking areas
make sure there is no sharp bends also
disconnect at motor and look for something binding on the motor.
maybe something got dropped and is binding things up around some of the linkages or other moving parts
Yes, start with the motor side of things and disconnect both throttle and shift cables at the engine and then play with the controler (I purposefully misspelled that!) to try and narrow down where the issue is. You can do the same at the controler. Doing those two things will pretty much pinpoint the culprit. But 9/10 times the problem is old cables.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Ok. Will check all those things soon, I looked it over already, kind of odd if this happens and I put it in gear (I don't put it in gear anymore its hard on gearing) that I can have smooth operation of controls otherwise its only right at neutral position the problem exists.
