Trouble starting yamaha f40bet carb version
  • Trouble starting yamaha f40bet carb version
    Hi I am having trouble starting my yamaha f40bet it's the carb version
    The engine has trouble starting it turns over without firing for ages.
    I turn her over for 5 seconds at a time then leaving her for a while and repeat.
    After 5 or ten minutes of this she will start to fire then after a while longer she will run but rough.
    Once warmed up she runs fine and will run fine all day but come back tomorrow and I'm back to square one.
    I always use fresh fuel and run the carbs dry when done.
    I checked the plugs they are fine but changed them anyway.
    All 3 plugs are sparking fine.
    Any ideas what I should look at next?
    Many thanks
    It is the carburetors. Arguably the most complex and troublesome set used on any Yamaha.
    If it is just a cold start issue (you are a lucky man) then you might want to look at the fuel enrichment system aka Primestart.
    Is the accelerator pump working? As a band aid approach you can quickly advance the throttle several times before you attempt to start the motor. It will provide some additional fuel to help get the motor started.
