I am rebuilding a F300 that appears to have failed because the nikasil cylinder plating failed. That in turn lead to excessive blow by which the F300, which runs _very_ cold by design, could not flash off. The blowby was confirmed with leak down tests. That lead to fresh water accumulation in the oil which lead to lots of badness. The shit hit the fan when 3 of the 4 camshaft seals failed because their springs rusted after which the engine blew 4 of its 6 quarts of oil out the seals and I never got a low oil pressure warning. So I have some questions:
- Has anyone ever converted the F300 4.2L block from sleeveless to sleeved? If so can you share details? I have been emailing with both Melling and LA Sleeves. LA Sleeves has a sleeve made for this block but I ended up ordering a similar sleeve from Melling, the CSL1149, since they were in stock. Googling shows many people converting from nikasil coated to sleeved on various mercury racing engines but I can't find anyone that has done it on this block.
- Has anyone else experienced similar failure to mine?
