I have a 2005 150 4 stroke, when raising my motor it malfunctions sometimes, not all the times, when it happens neither the engine switch or front switch will work, I hear the relay clicking and eventually it works, the pumps are not making any strange noises and have not seen any leaks, can the relay work and sometimes not work, connections are tight but I have not checked the connection on the trim motor, any help would be appreciated
Tilt and trim
Relays can wear out. They can still physically "click", but the contact patch inside the unit gets degraded/smaller... which means it can pass voltage, but not enough amperage to power the accessory.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
