C40PLRU tach settimg 3P or 2P
  • C40PLRU tach settimg 3P or 2P
    Title says it all:
    Should I set my Sierra Marine Eclipse Tachometer (Sierra Marine Eclipse Tach) to 3P or 2P setting for a 1996 Yamaha C40PLRU 2-stroke engine? I thought it should have been 3P, but the readings were very low... I switched it to 2P and I think they are closer to correct.. but am not sure.
    Thanks for any advice you can provide!
    Did you not get instructions with your tach?
    3 cylinder Yamaha C40 should be 6 pole
    2 cylinder C40 should be 4 pole
    At least that is what I see on here
    http://faria-instruments.com/site_manuals/IS0086t.pdf
      Sure,it came with instructions - which I read - and they suggested 3P for a 40hp Yamaha.. and made no mention of the cylinders.
      You linked to Faria instructions (I don't have a Faria tach) and even they are unclear. They make mention of a C25 - 55 which may cover the C40 at 4 pole, but they also show a C/P/E 30-70 at 6 pole... image attached - see, clear as mud.
        A 1996 C40 uses a 4 pole set of magnets to create electricity.
        Number of cylinders used do not enter into the equation.
          C25 - 55 is denoting a range of models. A C40 fits within that range.
            Thanks Boscoe, that confirms that I chose the correct option.. What document did that come out of?
              Top document came from a Yamaha tune up specifications book.
              Bottom document was a snippet from the document that 99Yam linked us too.
                If you notice in the fiara link the C25- C55 2 cylinder motors are listed as 4 pole
                The C30 - C70 3 cylinder motors are 6 pole
                I have no idea how many cylinders your motor has, so that is why I posted what I did
                  Yes, I noticed that, in fact I pointed that out shortly after the link to the Faria manual was posted and mentioned that the whole thing was clear as mud.
                    Seems you are having a hard time deciding how many cylinders your motor has or I am miss reading what you write
                      The number of cylinders don't have anything to do with the number of poles, otherwise the C30 would be a 4-pole and not a 6-pole... no?
                      I'm going with the information from the service manual regardless...
                        OK I looked it up and your 1996 C40 motor has 2 cylinders
                        And the chart I posted shows that a 1984 and newer C40 with just 2 cylinders is a 4 pole
                        A 1984 and newer C40 with 3 cylinders has 6 poles
                        I do not see where the problem is with the chart
                        Now I could understand where the confusion would be when you have to decide between the 2 and 3 settings you listed
