Yamaha 115HP 2020 outboard anodes
  • Yamaha 115HP 2020 outboard anodes
    Need help to find anode number 2 on my 115hp Yamaha 2020mod
    If you look on the Maintenance Chart in your Owner's Manual,
    that anode is listed as
    "Anodes (internal) * 2"
    with a 5 year / 500 hour replacement schedule
    On the starboard side,
    remove the intake manifold,
    then remove the Vapor Separator Tank that is behind it;
    on the side of the block is this cover:
    remove the nine bolts holding the cover on,
    that anode is behind it, screwed to the block.
      Thank you :-)
