30hp model AE, loses power at 3/4 to full throttle. It seems to be a fuel issue. When it starts to lose power I can squeeze the bulb once to keep it running for another 30 seconds or so until it starts running weak again. Squeeze bulb and it improves. Could drive around all day just fine if someone wanted to sit in the back of the boat and squeeze the bulb every so often.
Originally took the motor into the shop because I was having periodic bogging/flooding issues and when you squeezed the bulb to prime it you could just pump fuel past/thru the carb. Guessing a float was stuck and carb needed to be cleaned up.
Shop put in a carb kit, new fuel pump, new spark plugs, all new fuel lines under the hood. Did a compression check which came out ok. Took out thermostat which had disintegrated.
Took it out and motor starts right up, idles, low power is just fine. full throttle it can't get enough fuel and has the 3/4 to full power issue. I then replaced gas tank, fitting at gas tank, fuel line and bulb, fuel line fitting on motor side. Still the same issue. Shop said the new fuel pump might have been faulty - they warranteed it and replaced. Still same problem. They are at a loss and don't seem to want to look at it anymore. Their next guess would be to put an electric fuel pump on. The motor had no issue with the original fuel pump aside from the original carb issue, am doubting I need a different type of fuel pump now.
What's next?
Also would like to know what year the motor is, the serial number look ups I find only go back to 1984. Was told this was a 1990 when I bought it. Serial #689 S 103993
What's next?
