Top carburetor is blowing fuel out and choking out the motor were it won't go. I put a rebuild kit in it and is still flooding it out here is what I changed.
gasket,gum cap, valve seat 01.4 float valve, clip, valve pin, float comp, arm pin, flot/c washer, o ring, packin screw pilot, ajast screw, o ring..
Is there something that didn't get replaced that is causing it to flood out or is it time to replace it..? Any help is greatly appreciated thank you..
