Yamaha F225 water thru Exhaust Housing
  • Yamaha F225 water thru Exhaust Housing
    Hello,
    This picture is of my F225TXR (date: 05/06). It may not be too clear but this is a shot i took of my borescope looking up the exhaust when i removed the lower unit. I ran water up the pickup tube with a garden hose and i see water coming out ONLY from that square hole i circled in yellow. Is that normal? Does that come off the poppet valve or something?26378D95-4A95-4D1F-B9B1-176DD920FACD.jpeg
    That hole is towards the back of the engine and about where the exhaust housing connects to the oil pan more or less.
      Theses year/models are notorious for the mid section to corrode and eventually leak. It will only get worse. They make a repair kit for these but they are not cheap and rather labor intensive.
