Is there a reason not to use Mobil 1 full synthetic oil in my 2016 F70 with 81 hours on it?? I use it in everything else I have.
Mobil 1
Mobil 1 is a fine oil. is it worth the price???
For outboard motors they have a specific oil rating of FC-W. Per NMMA------- "NMMA recognizes that marine engines face unique demands compared to non-marine engines. In addition to exposure to humidity, freshwater and saltwater, marine engines are often run at high speeds under heavy loads"
I have always understood it that these oils have additional additives to help with corrosion since they are exposed to so much moisture.
Is that saying you have to run a FC-W oil in your outboard...NO. Will Mobil 1 hurt your engine?..Probably not... I run mostly Yamaha/Amsoil in our engines. I Usually change the oil once a year or every 100 hrs. whichever comes first.
