Hello,
I have a new problem on my F225 TXR. Sometimes when i let the engine idle too long, or when running for a few minutes then dropping the rpm and letting it idle or when going slow in a channel it would sound a solid alarm. The engine does not turn off and I can see the tell tale water stream flowing out fine. Im not sure if the amount of water coming out is as strong as it should be but it does flow out. Then i shut the engine off and turn it back on and it goes away. Sometimes it does it again, other times if i gave it some speed it goes away. Can this be waterflow/overheating related for sure or can it be something else. I have heard of things such as wrong/mis adjusted shifter position? Anyways, when I have time I would like to remove the thermostats and anodes and take a peek inside. I dont know how well the previous owner flushed this engine. What do you guys recommend me to do or check for first? Any good flushing ideas to try and products i can use such as barnacle buster? Although in order to use Barnacle Buster it says i must remove all anodes. Let me know your suggestions. Thanks.
