You can also use a hammer and punch, but you might bugger up one hole a bit. if you apply liberal heat and then after a couple of good whacks u will unseat that nut. Then finish removal using an adjustable pin wrench . You have four holes..only ruin the one ?? lol..
No, I'm ordering the Armstrong spanner tool. I've been told via another site that the tilt is a different size than the trim cylinders. That didn't make sense and my memory told me they looked to be the same span.
