Finally took the boat out today for its first test.
She wont idle very well at all. She will stall right away.
It seems like the pilot jets are clogged.
When under throttle she ran awesome!!!!
She would run great over 800RPMS.
When idle she would die at around 300-500 rpms.
I think thats a bit low, what should the idle speen be on this motor?
What are your thoughts on the idle problem?
Thinking some new or octane booster, new plugs and hopefully that helps. Trying not to tear down carbs and do a rebuild??
Any other tricks to try to idle better?
Dan
Dan
