Replaced water pump on 07 225 HPDI. Shifter in neutral before removal and when installed. Everything slide back into place, shift tube and shift rod. It'll go into forward but not reverse, I can move prop shaft and it'll go into reverse but not forward. I drop unit several times but it still does the same as above. What do I have out of alignment?
225 HPDI gear shift problem
