I re-powered with a 1993 130hp. Gauges were shot so purchased a set of used digital gauges 6Y5-83500-03-00 and 6Y5-83500-A0-00. Problem is with fuel tank full gauge only reads about half full when tank is filled. I rewired the pink wire from sending unit to white wire from gauge. I guess ground is running to some spot on the tank that i can not see. The sending unit has 5 screws holding it down with an additional screw that I assume is used to ground the gauge if needed. To rule out if ground is bad I ran another ground straight to the screw on sending unit but it did not change anything. I read where some of the yamaha fuel gauges had dip switches to set if not a yamaha sending unit but this one does not appear to have switches to change. Few questions if anyone can give me some advice.
1. They would not be internal switches that I would have to take gauge apart to access would they?
2. I removed the sending unit and it checked it with ohmmeter and the resistance did change. Using the numbers on unit (8341-70-896) I can not find out who makes it to see what the spec range is suppose to be. Are they generally the same for all sending units?
3. when the key is turned on the gauge does come on and the bars go to the full position but I understand that all of them do that when first powered up with key. Is that correct? And is so I would have to assume that digital/LCD bars above 1/2 full on the scale of bars are working and not burnt out/malfunctioning. Is that a safe assumption?
4. I also removed the sending unit, grounded it and moving it by hand could not get the bars to go any higher. I could get them to drop but not go higher that 1/2 which is what it read while installed. So I took that the float mechanism was not moving up high enough out of the equation with that.
5. If I disconnect the sending unit the bars drop all the way down to empty and the fuel light starts to flash which I understand is what is suppose to happen. Then when I ground the pink wire at sending unit the gauge then goes to full. Is this the correct way to test wiring and gauges and point more toward sending unit?
6. Is it possible that the sending unit is not giving correct resistance reading even though it is changing? Or can the resistance be correct but gauge is not reading it correctly?
7. one last one please. Is it correct that they changed in 94 so if I wanted to upgrade to any newer digital gauge for after 93 I would need to get additional wiring harnesses to convert to newer gauges? Could I convert just one of them (fuel) and not have to upgrade tach to the new style? If i convert to analog then they will not be lighted correct?
thanks,
GLS
thanks,
GLS
