So 2001 Yahama HPDI won't run. I can get it to crank and run roughly in nuetral if I increase throttle but as soon as I try to get it to idle it kicks out. Gas in the motor sat for 11 months due to winter and having a surgery (with ethanol....yes I know it was dumb and Im never putting ethanol in this engine again.)
I siphoned out all the gas, put in 25 new gallons of rec fuel, added startron and ring free, put in a new fuel water separator, new paper filter in plastic canister, new medium pressure fuel filter (metal canister), new vst filter, and 2 new low pressure fuel pumps.
Hooked it up to muffs and having the same exact issues. It sounds as if its starved for fuel. Master technician is backed up for a whole month and not being able to go fishing just flat out sucks. Any ideas?
Also....have a 9.9 four stroke plumped to the same fuel water separator and it starts and runs perfectly??!!
