I've picked up an old 80's/90's Yamaha C15 2 stroke which is only firing on one cylinder.
Swapping the wire to the coils moves the problem to the other coil confirming both coils ok however if only one coil is connected at a time there is no spark to either...ie both coils need to be connected albeit only one fires.
From the pick up there is an orange, grey and black wire. The black is the earth. Both grey and orange have twin female bullet connectors (why twin ends by the way?)
The emergency stop has a single white wire with a male bullet connector but no matching female anywhere (other than on of the two "spare" pick up ones?
Does anyone have a wiring diagram or idea why it is only firing on one? Under the flywheel is there two pick ups? ie one for each cylinder, maybe one has failed? Is this common/likely. Also where does the single white stop switch wire go?
All suggestions welcome
thanks in advance
JR
thanks in advance
JR
