Just got the boat last year. The engine started no problem after winterizing. However, piss hole stopped after a few minutes. Pulled lower unit and anodes (replaced) flush water up through cooling supply and flush out a lot of crap. I had already replaced thermostats and impeller mid-season last year. Put everything back hooked up flush connection and got a good stream. Used muffs and ran the engine getting a good stream as well. Dropped in the water a week later and the engine would not crank. Starter engaged but would not spin. I was unable to spin flywheel by hand. Pulled my plugs and spun the flywheel. I was able to crank with the starter. Looked like water came out of the lower starboard cylinder. (don’t know the cylinder numbering). Replaced the plugs and it started right up. Ran the boat up to 5500 (twin engines). Compression check shows180 on all cylinders. No evidence of water after running. Exhausts kits and oil pump were done in 2016.Is it possible the extra pressure from using the hose flush port was strong enough to force water in but water pump lower with psi does not.I flushed engines last summer with out any issues. Where did I get the water? How bad? Where do I start?
Past summer I spun a cam sprocket, replaced it as wells belt and tension assembly. Now I’m wondering if the current problem existed and caused that problem.. Thanks for any input.
