where does the flush hose terminate
  • where does the flush hose terminate
    SX250 2000>>>> The flush hose seams to have let loose ..When I flush the engine water is coming out of the cowling . Can anyone tell me where this hose terminates. The hose is part number.. Lower cowling schematic ..... thanks
    I'm not quite following what part/end of the hose you're talking about. But, I think you're talking about where the flush hose terminates at the engine? Start the engine with cowling off and look for water squirting out somewhere? There's gotta be a bare nipple somewhere in the vicinity of the length of the hose, right? Plus, the hose should be pretty well "formed" to a certain shape by now which would make it easier to see where it "naturally" wants to go.
      Ingesting water will hydraulic a piston connecting Rod
      OUCH ! That's not a good thing.. Matter fact, its down wright ugly
        My recollection is that the flush hose connects to a nipple on the exhaust manifold cover.
        If the hose is not connected then when running the motor there should be a stream of water coming from the nipple. Find the source of that water. That would be the connection point.
          does the boat and motor live on a trailer, on a lift, or sit in the water most of the time?
          make sure the water pump has water to pump before starting when looking for where the hose came off of.
