50 hp 4stroke won't crank. Tilt works
  • 50 hp 4stroke won't crank. Tilt works
    I recently added a new 24v ***** motor up from 12 volt and wired with a jumper and 50 amp breaker. After connecting all accessories, jumper, ***** motor and motor to batteries I ran into the problem of tilt, accesories working, ***** motor working but engine won't crank. Can someone please assist me? I really don't want to take it to get serviced. Thank u
    If it was working OK before, then double check your wiring job, how did you get the 24V and how did you maintain the 12V to the motor?
      Of course you have checked that the gear lever is in neutral?
        Not sure that you did, but You should not include your 12 v starting battery in the 24 volt *****ing system.
          Yes I did accidentally have it wired 24v to the motor. What could the damage possibly be? Is there a fuse that may be bad or have I screwed the pooch. Jeez Thank u
            Anything 12 volt run on 24 may have been compromised.
            relays, electric motors, etc.
            Ohm meter should show if winding's opened up
              10-4 will see what can get done
