after replacing the wiring harness, i am now getting the overheat alarm at idle. the pisser shows flow, but it is marginal at idle.
BEFORE i split the foot and replace the impeller, should i dismantle the check valve and check for an obstruction. the manual is lacking in the description of the cooling flow and passages.
