I have twin 150's on my boat - how can you tell which engine is feeding the speedometer? I have a clog and the mechanic is having a difficult time solving the issue. only getting about 30% of the known speed. Can the engines be swapped out by reconnecting a plug?
Speedo problem on 150's
speedo
Hummm,, you use the word "mechanic" loosely..cause that guy sure aint!! One of the tubes from the motor will run up to the back of the guage...Very Important that he rehooks it up super duper or will come off and wipe out your wireing..something Ive seen Waaay too many times
Try a version of this, at least using air from the console, blowing down to the engine.
Look and feel for water/air coming out the leading edge of the LU;
http://www.yamahaoutboardparts.com/f...g-th23159.html
This set up will keep your speedometer working correctly indefinitely if done on a regular basis.. Mines 8 years old now (salt water use).
BTW, they'll be a black HOSE, a little larger than 1/4" traveling from one of the engines, with the rest of the wires. About a foot and a half from the engine, WILL BE a male to male hose connector. That's your speedometer hose...Last edited by TownsendsFJR1300; 08-12-2015, 06:52 PM.Scott
ÂÂÂ
