2006 F250TXR with 2,500 hours. I have twins on a 33 foot Grady.
Discovered my Port Engine Oil was brown. I seem to be getting water in the oil from somewhere.
I am on the wait list for a repower (F300 digital controls) but that will likely be 2023 at this point.
I do not have a trailer and it would be a large expense for me to take my boat to a yard where the power head would be removed and leak repaired.
I had "the kit" to replace the exhaust mid sections + new oil pump installed just over 4 years ago (Feb. 2018) by a Yamaha Master Mechanic when the engine had 1,464 hours.
The exhaust manifolds were not problematic and showed normal signs of wear and tear for a 12 year old F250. I did this job as a precaution.
I'm thinking not to spend big $ on a repair only to toss the engine in 6-9 months.
Question: I can live with brown oil until I get my repower early next year?
My intent is to change the oil every 30 hours or so to keep the viscosity at a reasonable level.
Oil is cheap. One hour of labor is $125 or higher and I'm just trying to get another 6, 8 or 12 months out of this engine.
What would you do? And, would synthetic oil hold up better with some water in it than regular oil?
