Folks,
I could really use some help as I'm stuck.
Here's what I know. Took boat out for a 2 hr ride. Get back to dock, engine idling and it stumbles and stalls...strange. I pump the bulb, restart and seems OK. I watch the dash fuel flow gauge and it shows no flow. Clearly the LP pump is not running. I figured I was in for a costly new pump. Before blowing $500 i figured I'd test power to the pump.
Pump connector gets steady +12v on the red/yellow line. The blue/white line never gets continuity to ground (doesn't get commanded to run?).
Sounds like either the pump con*****er or ecu is having a problem ( or potentially wiring which I doubt but is possible).
Any tips on finding the offending part?
Thanks,
Joe.
Thanks,
Joe.
