2006 f225txr
  • 2006 f225txr
    ok im back to square one i changed out the water pump i cleaned out and replaced filters on the VST had the corrosion checked and now it still does the same thing it has been doing
    roughly around 5400 rpm it acts like it is kicking out of gear goes bang and rpm goes to idle move to nutural and start again gets to around 3000 rpm and it does it again back to nutural and try again to go 2500 rpm same thing
    ended up limping back home to the trailer @ 6 mph roughly 1800 rpm
    took me 1 hour to get 8 miles
    At wits end with this thing
    700 hrs on motor
    I'm not sure if your motor have low pressure fuel pump. My OX66 did the same thing. Cause was a rip diaphragm on low pressure fuel pump. Gas get suck in crank case .
      no i checked that
      did kinda deduce that with everything that i fixed was for the good but i didnt get the alert codes reset yet so i think it thinks it still has a problem
      software and connection cord show up around the 28th of this month so i must wait
        instead of buying expensive stuff that you have not a clue how to interpet, simply fix it.?????
        YDS wont tell you what is wrong.
        it will tell you what ghosts or bunnies not to chase.
        YDS is a decent tool. wont replace the tool on the spinal colum.
        l
