Have you done anything to see where it might be coming from ie check for loose or cracked oil lines or oil pump linkage not attached causing pump to be at max oiling when idling...ect
2 stroke oil….likely leaking from main oil tank or one of its hoses then dripping down mid section. With that much oil leaking it shouldn’t be hard to pinpoint where the leak is in oil system.
