Hey guys,having a rough running issue with my 2 stroke 60hp 2001 i hope you can help me with.
When the engine eventually starts it runs very poor and a strong smell of fuel.
So..............
All 3 carbs removed & cleaned found 2 of the 3 carbs with green making the float needles sticking.
All 3 plugs changed
Fresh fuel !
Compression check 150psi across all 3 cylinders.
When i start the engine and pull off no 3 cyl i get no change in engine tone but when 1 or 2 removed the engine cuts out.
Swopped out cyl 1 coil for cyl 3 & checked all wiring to cdi for corrosion and all ok.
But rough running still seems to be no 3 !
Any help appreciated as i have removed the carbs at least 30 times now to make sure i haven't missed anything.
So..............
All 3 plugs changed
Fresh fuel !
