Hello,
hopefully someone here has some knowledge too help me whit something.
im im having big issues whit this thing. the "choke".
I have a 2000 modell F50 4stroke yamaha, and i can start the engien just fine.
but it runs very high on RPM when ideling, around 1900rpms.
and after a minutt it starts too run high, i have too turn the engien off when it hits 3500rpms.
but, when i press down the levers on the carbs that the "choke" is supose too control it runs smoothly on 900rpms. and it can run like that forever, as long as i keep the levers down.
i see that the "choke" is not moving, it only moves for like a second while i turn on the engien, but when it has started it stops working.
iv traced the wiring too the starter relay, and iv mesured the voltage on the "choke" i get voltage there just as i turn the engien on, but as soon as i let go of the key and its started it looses all voltage and stops working.
i tried too use another circut with constant voltage just too see if it was working, and then the "choked" worked fine, it was holding down the leveres, but then i couldnt use the throttle too give it gas, too gain rpm because it was holding the leveres constantly down, and the engien just bogged down and died, so im guessing it should be getting variabels voltages?
hopefully someone here can help me so i can save the rest of the season overe here, and sorry for my poor english, im norwegian and living up here in the cold north, and only got a few more weeks of summer before the real cold sets in
whats wrong? anyone have any idea?
the choke is supose too adjust these leveres.
(hopefully the image works)
![](http://baatplassen.no/bildekatalog/60/60327/1438438839.jpg)
