Inherited 2001 225VX OX66. Likely no real maintenance done other than gear lube. I have performed some additional basic maintenance. Replaced water pump, gear lube, spark plugs, thermostats, low pressure/high pressure fuel filter. Three new low pressure fuel pumps on the way.
Engine runs OK but not great. Frequently stalls at idle. Seems to idle a bit rougher than I would hope...but all in all, not terrible. Dig out of the hole, planes and runs well until about 5100 RPM. The motor shuts down like someone pulled the emergency lanyard. Sometimes it has to be restarted. Sometimes not.
From research, this sounds an awful lot like a fuel issue. GIven the expense, I'm really hoping it's not the high pressure fuel pump. I also want to test the O2 sensor. Pretty sure it's never been tested or cleaned. However, I'm willing to test. That said, I'm not sure how. I have a fuel pressure gauge. I have a good Fluke multimeter. However, I don't know what testing harnesses I need to test the right systems to diagnose this problem. Any advice would be greatly appreciated.
