Intermittant Electrical issue
  • Intermittant Electrical issue
    This just started happening. I cant replicate it, it happens in a way that seems random. I'll post some pictures as I was able to capture the issue. Any diagnosis help is greatly appreciated.
    Twin 2017 F200's almost 900 hours.
    Occasionally, the starboard engine seems to "disappear" as if it wasn't there at all. In the attached video you'll see me try to start it, and the RPMs go from "00" to "--" On the Garmin screen, you will see the collage for the engine did not drop. When this happens, the Yamaha display shows no engine data at all, such as Hours, Voltage etc as if it was completely off line. Using the battery selector to "Combine" all batterries, nothing changes.
    After a few times turning the key on and off, it just comes back online and starts as normal.
    During the time the engine appears offline, the trim button on the throttle control will not operate trim, however the trim button located on the engine will work and raises the engine like it has full 12+ volts.
    Additionally the Blue indicator light on the throttle is not lit.
    Fairdeal? Where is he?
