Does my 2006 f25 tlr have a restrict or plate in the air intake ?
Restricted plate
I don't think so as the F30 is a three cylinder meaning that the F25 is not a de-tuned F30Last edited by greasyshaft; 07-24-2015, 08:48 PM.
Your EXACT model # would help but here's the parts fisch for the intake for an 2005 F25
2005 F25ESHD Yamaha Outboard INTAKE Diagram and Parts
This above engine, is a two cylinder... That's why MODEL # 's are critical
.Last edited by TownsendsFJR1300; 07-24-2015, 06:47 AM.Scott
Rumor has it that if the restrictor plate is removed your model will become an F50. The HP will double. At least.
Some remove the existing intake system completely and install an air pipe that goes directly from outside the cowling to the air inlet of the carburetor. They are reporting an additional 30 or more HP. So much torque is produced that you have to be gentle when advancing the throttle.
Here's the correct intake parts fisch for your engine;
2005 F25TLRD Yamaha Outboard INTAKE Diagram and Parts
Are you referring to part #3?Scott
