Aloha. I recently bought a boat from my friend. And I’m super embarrassed to admit this. But while doing the compression test ourselves, we disconnected the fuel, but did not pull the kill switch on the key lanyard. Halfway through the test, the whole engine died. No power, nothing. We disconnect the battery and retry. Everything goes well. Good compression. Engine starts fine, but now has a misfire. Changed to new spark plugs, but still misfiring. Did I possibly burn out the ignition coil assembly when doing the test? I figure that would be the next spot to check since I know the spark plugs are new. Engine was fine before this during the sea trial so it was definitely me effing up the compression test that caused this. Please help
2011 Yamaha f70
2011 Yamaha f70
