Hello
My T9.9GPXR (2009) ALERT system kicked in after running at WOT for about 2 hours. I checked the oil before running it and it was good but after 2 hours the level barely read on the dip stick.
I did find oil dribbling down the front side of the Upper Case Assembly (behind the tilt mechanism).
Since topping it up I have run it for more than an hour at 3000 RPM and the oil level has not dropped at all. The engine has less than 250 hours on it and I find it hard to imagine a seal letting go but of course that could be the problem.
I am wondering if the Oil Pressure Relief Valve might have activated?
Does the relief valve reset automatically once the oil pressure goes back down?
What would cause high oil pressure if the relief valve did blow off?
I am reluctant to pull the power head off at this point but equally reluctant to run with a possible oil leak.
Not sure how to proceed, any thoughts would be most appreciated.
