2007 yamaha 50hp 2-stroke carb
  • 2007 yamaha 50hp 2-stroke carb
    Does anyone happen to know what this gunk in the carb is? Any help would be appreciated.
    I have no idea what that is,
    but did you find water in there?
    looks like it was
      From what little I know, sodium sulfate. It precipitates out of gasoline.
        Needs water to form those crystal whatever they are. Question at this point should be about inadequate filtering?
          and check tank for free water in the bottom of tank
            A fuel/water separator type cartridge filter mounted on the transom should help prevent this….then drain each carb float chamber about once a year at the end of the season…
