2005 150 TPS Questions
    Originally posted by pstephens46 View Post
    Just to confirm. You have a 15 pitch prop with a 15 inch diameter?
    4 blade to boot? Seems like a lot of metal to swing. My F150 HAD a 18 pitch 14 1/4. Ran 5900rpm. What type of boat and weight? My boat weighs around 3300 lbs with no bodies onboard.
    That's correct, 4 blade 15 pitch prop with a 15 inch diameter.
    Boat is a SeaPro 206CC. Its your typical deep-v center console with a T-top. Advertised weight is 2200lbs but I assume thats dry and possibly no outboard or 75gal fuel.
    Best case scenario is that its too much prop. I just replaced all fuel filters including VST and fuel injector rehab. If no change on the next trip out, I will start playing with different props.
