Finally got the twin F225A running enough to check the fuel management gauge. on the 2nd tank refill the system was reading 12% more fuel burn than actual. The calibration switches ONLY allow for +3% and -3%, my last boat had single engine and was spot on with out adjustment. Any suggestion on what may be going wrong?
twin F225A's Fuel Management
I was only looking at the total gallon(s) reading. The speedo is a seperate gauge. Never switched to gpm. However the speedo is reasonably accurate
FMM wired to speedo, can be connected to GPS if that is better source,, ohh.
New sending units, new cable,
ÂÂÂÂÂÂÂ
