I do not think cleaning injectors will increase pressure on rail.
Stuck open injectors may have an effect on pressure but not sure if it will lower it like that.
Just because you replaced it before does not mean it is still not a problem.
Hope some one else will drop in and say one way or the other
I don't think the OP is asking about more fuel pressure. I think he is asking about clogged injectors failing to provide needed fuel. The fuel pump for his motor is rated at nominally 700 psi.
To the OP - If you have 700 psi output at all times, if the ignition is working as it is supposed to, if the throttle is opening wide open, and if the compression in the motor is good, then you may just need to have your injectors serviced. I recommend Brucato Injector Services.
Everything else seems to be working fine. I am going to have the injectors pulled , serviced and tested.
Replaced injector #4 with a used injector. 5300 rpm. I think it was suck open and washing out the cylinder. I'll have them all pulled and serviced this winter
