I have twin 200HP HPDI ( i believe Z200TRLY). The starboard runs fine, the port is acting up. Both run off the same fuel tank.
I was topping out at 4200 RPMs on the port (should be 5200 or so). Over about 20 hours, the 4200 top dropped to 3200 and eventually to 1500.
I though at first it was the VST. Replaced that no luck. I checked the electrical, there was some corroding on the connectors, so i cleaned those up. Getting 12.45 V at the posts. twinned the port to the starboard battery feed to test.
I pulled the spark plug wires one by one at idle to confirm that were working. I switched fuel lines on the motors. I ran an new fuel line from the water separator into the motor (also hooked to the starboard separator to test). I replaced the water separator as well. none made a difference.
put everything back to normal, I then replaced all the spark plugs (NGK (4952) BKR7ES-11) back up to 4200 for a while then the plugs fouled, rather quickly (2 hours). back to 3300 RPM.
I replaced all of the plugs again, back to 4200 RPM, but now if I rev the motor in neutral, it boggs down at 1500.
I am now baffled by why the plugs could possibly foul that quickly and why it wont rev in neutral. I don't think it is the fuel or oil since the other motor runs fine.
Any ideas of what to check next would be greatly appreciated. Summer in the northeast is very short.
Thanks for any help.
