Originally posted by 99yam40
View Post
T9.9ELHR fuel filter
Fuel Supply Issues
I have had two separate problems in the past five years, both which had the symptom you describe. The first time I had fuel tank crud collecting against the "spring-ball" check valve where the supply line connects to the tank. Got rid of the check valve, and installed fuel water separator to deal with the crud.
Last year, similar symptoms (starvation) appeared, this time it turned out that the primer bulb was actually restricting fuel flow. I guess something came apart and/or lodged inside it to partially block the supply coming through. Just a couple of thoughts about possible causes..........
ÂÂÂÂÂ
