I had a weak water stream and disconnected the hose from the pee hole to the water jacket. The hole in the block had white corrosion built up in it. I cleaned it out with a piece of wire and the stream was much better. Can I pull the thermostat and pour something into the water jacket to clean out the corrosion? Thanks.
1987 70 water jackets
