Short question and then some background:
I removed the CPS from my 1997 90TLRV (2 stroke, 3 cylinder) in order to test it. The engine was rotated with the CPS off and now I wonder whether I need to align the engine before I reinstall the CPS. I’m concerned about getting the timing/firing correct with respect to the position CPS relative to the Rotor Assembly. Does anyone know if there are any alignment/index marks which correspond to the installation of the CPS? I’ve searched in the Service Manual (LIT 18616-01-69) but can’t find anything that references this. Any help will be greatly appreciated!
Background:
The problem I was having is that when I first start the engine, there is no spark on cylinder #2, and it doesn’t rev past 2200 rpm under this condition. After about 15 minutes and when the engine is warmed up, spark on #2 comes back and the engine runs fine all day. The problem started about 5-6 weeks ago as the air and water temps have gotten cooler. I’ve read a couple of posts on this forum which suggest that the CPS could be the cause of this problem. I’ve cleaned the corrosion off the CPS and it seems that the magnet now has a stronger pull to it. There are no cracks or any other visible concerns with the CPS. I plan to reinstall it, run the engine and if the problem persists I’ll continue with the diagnostics as per the Service Manual to determine if the CPS is still the problem or perhaps the CDI. Ignition coils and spark plugs are in good condition. Other than this issue, the engine runs strong and there are no compression or fuel related problems. Just hoping to reinstall the CPS without creating another problem.
Thank you
Background:
Thank you
