I have a F115 connected to a 703 remote control. Has run well for a few years and when last time used a few months ago. Recently went to check engine hours and with ignition switch on and deadman inserted the panel displays don't light up, trim controls don't work and it will not crank. At the motor the motor trim control works. . Batteries fully charged and set on both. Removing cover on the 703 it seems there is no voltage on any wire coming from motor and (without wiring diagram) assume there should be 12VDC and the ignition switch set to on connects panel instruments and with on start connects to a solenoid in the motor.
ignition switch has 6 wires - red, black, white, brown, blue, yellow - that all come from a wiring harness directly from motor as far as I can tell.
Any suggestions for further trouble shooting? thanks
