New to me 40hp,but not sure where to connect the positive cable from the battery.Not sure of the year either as the sticker is missing,can I identify by any other means?
Where do I connect the positive cable?
I believe Boscoe99 has said there should be a sticker on the block close to starter with some serial # or something like that that might help.
Post what you can find
Bad connections or battery maybe.
Have you monitored the voltage when you hit the starter or T&T?Last edited by 99yam40; 06-30-2015, 01:18 PM.
No voltage on other post or at starter when turning key either.No sticker on block.......Here is where I have it connected.
ÂÂÂÂÂÂÂÂÂ
