Hi.I have a oil transfer problem I think on a 2001 50hp it seems to be mixing oil to fuel at about 30to 1. I think it should be around 50 to 1, I do a fair bit of low speed work is there any adjustment on the pump also when you increase speed it takes a bit of time to clear also at top revs it seems flutter and the engine seems to stall very briefly back off a touch and it seems okay.
could it all be linked to the oil mix,i checked the compression they are all at 100psi.Hope you can help.Thanks.
