Hi there,
I have a Yamaha 30HP (6J8) with major problems with the tilt/trim/starter function.
By storing the engine over the winter in my boathouse, i had major problems with starting it in the spring time now.
The problem is that the relay asset box (part G82-SA1) is only "ticking" multiple times when i try tilt down, tick tick tick tick... I had the "ticking" also for tilting up the engine, but now thats one not either ticking.
So cannot lower the engine or raise it anymore. The same goes for the starting, as i belive the G82-SA1 relay asset box is con*****ing also the starter. So when trying to start i only have rapidly ticking in the starter solenoid also, tick tick tick so you can hear the start solenoid is working, but the "hold" function so the starter engine will.
The relay asset box G82-SA1 is brand new, still the same fault. Battery is OK. 20AMP fuse is ok.
Any that could have some ideas of what this could be??
