overheating at idle
  • overheating at idle
    2001 Yamaha 70hp 2 stroke overheating at idle, fine at 1000 rpm new impeller kit, head gaskets
    remove the stat cover and run the motor on a hose/muffs to see if water is making it up that high at idle, and then run it in a bucket to see if it also pumps water that high in the motor
